F fisherman58 Member Joined Sep 12, 2011 Messages 17 Reaction score 0 Location chicopee ma Sep 20, 2011 #1 the trim does not work some times from either switch i have checked connections and they all seem fine any ideas
S Sawdust Farmer Well-known member Joined Aug 15, 2011 Messages 115 Reaction score 0 Location NE Arkansas Oct 1, 2011 #2 Factory or aftermarket trim? Does it try to work, click, nothing at all??? I know you said you checked the connections, but the first thing I would do is check them again. Triple check the ground connection. sf
crazymanme2 Moderator Moderator Joined May 26, 2009 Messages 1,724 Reaction score 2 Location West Olive Mich Oct 2, 2011 #3 Start checking your switch with a 12 volt tester. [-o<
