1975 johnson seahorse 25hp high idle neutral
mangelcc
Kinston NC
Anyone ever ran into this. Sync and link procedure? Its a buddy of mines motor, it cranks first pull but revs very high in neutral. Put motor in gear and its fine. any ideas? Thanks
On the top of the carb at the rear of it you will find a roller. That roller runs on a cam on the bottom side of the mag plate. On that plate there is an alignment mark that is there to indicate the pick up point for the roller and therefore the carb opening. Re-adjust the linkage to allow the carb to remain closed until the mag is rotated and the mark lines up with the roller.
