How to remove Tiller Handle Gear on a 76 Evinrude 9.9 hp?
bobcat_fisherman
Texas
Any idea how to remove the Gear on the motor side that connects to the gear on the Tiller Handle side? As you can tell from the picture it snapped off at the base of the gear. If it's easy I might replace the gear on the tiller handle if ya'll think it needs it. I'm no mechanic, sorry if this comes off dumb. I know the gear is connected to a rod which runs inside the motor and meets up with another gear. Am I going to have to take off the starter and disconnect a bunch of gears that potential will throw off my tiller handle throttle timing?
Front view with tiller handle flipped up.
Top view with tiller handle in the down position.
Here is a link for some excellent reading and visual descriptions. Look under section #9 about half way down the article.
https://www.sschapterpsa.com/ramblings/Johnson_9.9_troubleshooting.htm
Here is a link to the rest of the articles regarding the 9.9/15hp Evinrude Johnson motors.
https://www.sschapterpsa.com/ramblings/OMC/OMC%20info.htm
