My 15 hp merc has a 9x9 prop now, on a 15.5' open v tinnie, total weight is never more than 900-1000 lbs with the largest load.
new to me set up, last summer
I'm thinking I need a prop with more pitch (there is a 9x10 1/2 listed for this motor) because at around 7/8 to full throttle (maybe less than 7/8) the motor speed is the same to my ear. So I usually run it less than WOT
I know I should put on a tach and check out WOT rpm's, and will do that this spring .
But I was wondering if anyone here has the same motor on a similar light loaded boat, and if you use a 9x10 1/2 or a 9x9 prop on it.
It just seems to be a little under pitched to me
I think about these things now, when it's still winter, and am looking forward to getting out in the boat again haha.
thanks for reading and any input
