johnson evinrude fittinging leaking at engine
62kodiak
cambridge,mn
I just bought a '62 evinrude speedtwin 28hp and the fuel fitting that mates up to the engine leaks pretty good. Is the fix as simple as buying a new fitting or just bending the little metal clip on the fitting? Should there be an O-ring on the female end to create a seal?
Throw a new fitting on...much less trouble. Yes, there is an o ring inside but, with a new fitting, the o ring, ball, and spring will all be new to give a good seal. Fixes everything with just one replacement.....
