wscruiser
My wife and I took out jon out fishing for the first time this year yesterday. It started and ran great. Howerver, later in the day, I noticed a slight smell of gasoline every once in a while . Upon inspection, I found that the prime bulb (which is less than 1 yr. old) has started to badly decompose around the fitting closest to the motor. If I would pump the bulb a small amount of gas would shoot out.
This afternoon we took it out again. Today when I would squeeze the bulb to start the cold engine the leak was worse. The engine started, but after it warmed up and I went back to idle it would shut off. I finally got it to idle low enough to get it into gear, so off we went. It runs great at higher rpms but cuts off when I go down to idle.
We drift fished for a couple of hours, not using the motor. When we were ready to move on, the motor had lost it's prime and the primer bulb was soft. I could see where it had leaked gasoline out of the bulb. I had to squeeze the bulb several times before it would build any pressure, gas would shoot out of the bulb with just about every squeeze.
I plan to replace the bulb this week, but my question is; is bad bulb causing the non-idle problem?
