How big of a deal is to change a thermostat on a 30 hp 1992 johnson 2 stroke?It looks like I just remove the cover on the back of the cylinders and that should be it.any tips or things to be wary of?thanks!
It will be easy unless you have a bolt that is seized and it snaps off. I just did my 88' 30hp and busted the bottom bolt inside the lower engine cover #-o Got it out with an Oxy/Ace torch though
Expect to find this behind that cover if it has never been off
