1956 montgomery wards sea king 5 hp crank seal
Jethroe
Lake Ft. Gibson Wagoner Oklahoma
Hi all,
I took it apart all the way down to the crank just to get to the seal because I paniced when I seen oil shootin out under the fly wheel.
Wished I hadn't gone this far now because I found out this is supposed to be normal for this model of motor 1956 Gale sea king #gg9002b because the seal is just a piece of metal and little or no oil should get past, but it does anyways I guess. Should I tighten the seal somehow on the crank shaft or leave it alone put it back together and just live with it leaking some oil?
thanks
