Question about Briggs and Stratton outboard
jt7257
Can anyone tell me why my motor wont suck gas. When I squeeze the bulb it just leaks at pressure fitting. Will not go into the motor.
If it's leaking then air is getting in the line preventing suction. When you say pressure fitting do you mean where the fuel line connects to the motor? If so, by pass it and try. Have you recently removed or replaced the fuel line? The bulb is directional so make sure fuel in is facing the correct direction.
