1977 evinrude 55hp hard to start warm
Mgraff00
My 77 rude is now running great. It starts super easy when cold as in unloading from trailer in morning. After motoring around and shutting it down it will pop while cranking but not run. Primer bulb is tight. Choked or not the only way I can start it is spraying a little ether in the carbs. At that point it fires right away and runs great again. Any ideas would be great. Thanks in advance.
It pumps water good but I figured on putting an impeller in anyways don't want a hot engine
Don't use starting fluid in a 2 stroke motor. Try spraying some fuel mix in the carb.
