I second this with testing & racing done on them.I will humbly disagree with "not going to get much better performance with an SS on a 20hp motor". I read these same arguments from people when trying to decide if I should go with a SS on my 30hp motor. Nobody could produce hard evidence to prove these claims so I purchased 2 different SS props and compared them to the 3 stock aluminum props I have and the upgrade in performance was substantial. The SS props perform better in every way possible from hole shot, planing at a lower RPM and overall top speed. I meticulously recorded difference in RPM and GPS readings on all the props and the SS's won hands down. I have heard that HIGH end aluminum props do perform like SS props but I cannot confirm nor deny since I have never tried them. I figured if I was going to spend extra to get the SS.
And I will agree with pappy, the hub should slip first weather aluminum or SS. IMO it is worth the extra $100 or so for an SS prop
Johny25 said:I will humbly disagree with "not going to get much better performance with an SS on a 20hp motor". I read these same arguments from people when trying to decide if I should go with a SS on my 30hp motor. Nobody could produce hard evidence to prove these claims so I purchased 2 different SS props and compared them to the 3 stock aluminum props I have and the upgrade in performance was substantial. The SS props perform better in every way possible from hole shot, planing at a lower RPM and overall top speed. I meticulously recorded difference in RPM and GPS readings on all the props and the SS's won hands down. I have heard that HIGH end aluminum props do perform like SS props but I cannot confirm nor deny since I have never tried them. I figured if I was going to spend extra to get the SS.
Johny25 said:Ok I never tried it on a 20hp, mine is a 30. And I do agree that the flex is not really an issue at this low of HP. The performance differences I believe come from a couple other areas.
1. thinner blade allows it to spin faster and easier (even though it weighs more than double)
2. blades can have more cup and better design due to material. On all aspects of the blades.
I found that I can turn a prop of 1 pitch higher in SS at the same RPM as the lower pitch aluminum. This can be backed up on plenty of prop forums. Turning a higher pitch at a higher RPM gained me between 1.7-2.2 mph on top end with a light load in the boat and 1.8-2.5 mph when I had a real heavy load in the boat. I could also keep my boat on plane almost 400rpm lower than any of the aluminum props. Now 2mph may not sound like much if your talking 100mph but when we are talking 25-30mph ranges that is a significant gain in my book. This is just info that I found and tested first hand and will not guarantee anything. But I would not give out false info either.
Higher RPM at a higher pitch= better performance
