tholdah
Thanks for reading my post. Any suggestions you have would be appreciated. We Bought this late 70's Johnson Sea Horse 35 HP motor for $200 "as is". We gambled buying it without hearing it run. It needed a fuel pump, water outlet elbo, and the fuel inlet connector. We replaced all of those parts (used $30) and the motor fires and runs great.
What we have now are 2 issues. #1 The seal between the lower unit (as shown in the pic) is not sealing. When we changed the lube, it was milky. Also, when running it on the water ears, we're seeing bubbles from the seam. I am pretty sure the unit has been serviced based in the new bolts, and it seems the water pump pumping really well. It just wasn't sealed well. We're pretty mechanical, but I've never torn a lower unit off an outboard...
Second problem. The motor mounts are wasted. There's way too much play. Where can I find some (new or used?). Also, can I loosen the outer bolts and tilt the unit forward to get to the inner bolts? (I'm sure my terminology is off here :roll: )
