I'm probably just dumb, but I cant figure out how to get the throttle cables off the motor so I can remove it to paint. Any help would be appreciated greatly.
I seen it. Problem is when I undo the clip, the barrels don't have enough room to come all of the way out. Are the barrels the only thing holding them in?
The barrels will just slip out & on the other end there will be a fork to accept your cable ends.There will probably be a nut or screw you have to loosen to get the end off.
