Motor mounts
Big Iron
What would cause the front motor mounts of a 40 hp outboard to wear out? These are the mounts that attach the power head to the upper part of the lower unit not the attachment to the transom.
They are at the front bottom of the power head and bolt to the power head and the exhaust housing
Ok let me ask the question in a different way. Has anyorne ever had to replace the motor mounts?
Not to hijack your post, but I have the same issue on the same motor. I have about 1/2" of play front to back at the top of the motor. Not sure if that's too much or not. I'll post some pics later today.
Rubber does age and wear out, especially when subjected to the fuel mixture. It is common to need to replace the motor mounts.
