My old 1542...
bought it with a '97 25 Yamaha 2 stroke (114 lbs). Sold the motor for what I paid for the entire boat, and picked up a '01 25 Yamaha 4 stroke which is around 140 lbs. That boat was about 1 mph faster with the 25esh (2 stroke). I had to carry 6 gal of gas to run to the favorite crappie hole. Roughly 12 miles round trip. When I put the 4 stroke on, it starts better, idles better, I only need to carry 3 gal of gas now, it has a better charging system, less maintenance, everytyhing about it is better other than its a bit heavier.
The weight is only an issue if you have to tilt it a lot. On mine, I just kick it in reverse and pull. Tilts easy that way-but keep in mind I'm bad lazy.
The F25 is now on my War Eagle. The WE is heavier and wider and deeper (344 lbs hull weight vs 207 for the old 1542) but it's still 2 mph faster.
The only thing I wish this F25 had was one more cylinder. SOmetimes I want it to be REAL smooth and a 2 cylinder 4 stroke just won't be as smooth as a 3 cyl motor-especially the way all of the twin cyl 25's are designed with their 360° firing order (both pistons move in the exact same direction at the same time-makes for a little vibration). I may end up selling the F25 in favor of an F40, but only an older 4 cylinder F40. 2 year only deal but I love them.
