clamp or bolt my 20hp?
mivison
Post by mivison »
Just bought a 1986 sylvan with a 20hp merc on it. It has holes for bolts I think. Does any one here bolt there motor that small to there transom?
rickybobbybend
Post by rickybobbybend »
Absolutely, bolt 'er on. And absolutely post some pics.
RickyBobbyBend
Gregor 1244 Welded V, Evinrude 9.9
Modest Mods on Gregor 1244 V: https://www.tinboats.net/forum/viewtopic ... 21&t=24612
mivison
Post by mivison »
You bet. Will post a pick tomorrow
crazymanme2
Post by crazymanme2 »
I feel there is no need to bolt that size motor unless your afraid somebody is going to steal it,which by bolting it would make it hardener to steal.
I have a 40hp Merc that I run & it isn't bolted.
Craig
Be Who You Are
And Say What You Feel
Because Those That Mind ....Don't Matter
And Those Who Matter....Don't Mind
tnriverluver
Post by tnriverluver »
Clamp it tight and forget about it. Makes it easier to remove for winter storage if needed also. If it is remote steer then bolting might be the better option.
Gramps50
Post by Gramps50 »
I have a tiller 20 hp Merc and it's clamped on, not had an issue. I make it a habit to check the clamps each time I go out.
--- Gramps
1985 1651 Polar Kraft 20 hp Mercury
HB 597 ci HD DI
JMichael
Post by JMichael »
You definitely don't need to bolt it for operation purposes but it does add a bit of security when it comes to preventing theft. I don't have mine bolted either.
Canoeman
Post by Canoeman »
Yup.. clamp it on and go..
If you want security get one of these..
https://www.perfprotech.com/outboard-mot ... duct/48170
mivison
Post by mivison »
Thanks all. clamp it is.
one more question.
Do you use a transom saver for a motor that size?
tnriverluver
mivison wrote:Thanks all. clamp it is.
one more question.
If you have a lot of ground clearance and can tow the boat with the motor down it isnt necessary. If not then it would be a good idea. I have a 20 hp 4 stroke Merc and I haul it in the down position in reverse gear to lock it in place and keep it from bouncing up and down.
Pappy
Post by Pappy »
By all means....bolt the engine in place. Not only will it help prevent theft but will also prevent the engine from coming off the back of the boat during a sharp turn. No, the bolts do not do anything while running in a straight line but in a turn....they do alot! The engine will swing up and its gone!
Also, as time goes, on the transom compresses and the clamp screws begin to loosen as a result, that is when you will go....."should have bolted it on"
I cannot tell you the number of customers I have seen through the years that have come in looking for replacement 9.9-15hp engines as a result of just using the clamp screws and the engines jumping off the back of their boats. Just read of a 25hp coming off the back of a Gheenoe in another forum on the first weekend of usage. That young fellow was lucky and found the engine three days later. It is running again and is now bolted in place.
JMichael
Post by JMichael »
one more question.
I won't tow mine without one, but around here we end up towing our boats on some pretty rough ground at times and that puts added stress on the transom if the motor is bouncing around. I've seen several boats with the transoms cracking from the bouncing. If you only tow your boat on smooth pavement and don't have to worry about ground clearance, then you might not have to worry about it.
I think that the majority of the ones I've seen damaged, happened because they left the motor in forward gear when they loaded the boat on the trailer. This left the motor lock disengaged, so any time they hit a pothole or bump, the motor bounced up then it would slam back down.
Post by Captain Ahab »
Use bolts and a saver - both will help
Bailey Boat
Post by Bailey Boat »
In most localities a small engine that can be lifted by one person will "walk away" at the first opportunity. My 25 Merc, 4stroke is not only bolted but it has McGard locks on 2 of the bolts. Lots of luck to whoever tries..... BTW, I shoot first and ask questions later....
Charger25
Post by Charger25 »
Bailey Boat wrote:In most localities a small engine that can be lifted by one person will "walk away" at the first opportunity. My 25 Merc, 4stroke is not only bolted but it has McGard locks on 2 of the bolts. Lots of luck to whoever tries..... BTW, I shoot first and ask questions later....
Agree
in all honestly it depends on where the boat is kept. A Bud of mine had his '74 18 hp Rude stolen off the back of his 14 ft. Lund boat. Whoever did it left drag marks down the gravel alley, either too weak,stoned or intoxicated to actually pick it up. He used to live in suburbs. I live out in the country, no probs here. But as a rule I do check the clamps before I launch the boat.
12ft ryancraft w/ 8 hp Frankenstein rude
14 ft fisher w/ 15 hp rude
16 ft lowe w/ 25 hp Frankenstein rude
9.9 Rude / sleeper
6 hp Evinrude Sail Master
