2009 Mercury 60 hp 4stroke EFI Mechanical Fuel Pump
BYOB Fishing
Cisco, IL
Alrighty, I was able to find a grainy image that gave me some confidence that my fuel/water lines were in fact crossed. But in the process of working on it, I removed the mechanical fuel pump on the back of the motor. Now, when I go to re-install it, it's like the threads on all four bolts are stripped out. I turn the screws all the way down and they don't get tight. I'm not sure why, it's almost like they were glued in place. I'm wanting to make sure that swapping the lines will fix my problems, but now since I can't get the mechanical pump re-installed, I won't be able to test it. Does anyone know what I may be doing wrong? Any help would be appreciated!!!
Matt
