NugHunter
- Joined
- Mar 5, 2013
- Messages
- 15
- Reaction score
- 1
last time it ran when i gave it gas it would bog down unless i let off the gas..it would idle ok..give it gas..bog down...keep pumping the bubble and it would run....now it wont start and backfires...i installed new plugs and if i pump the bubble while i pull it it wants to start but wont...i stuck a small screw driver into the gas line end and pumped the bubble to make just gas was coming out..it was...when i attach it to motor and pump bubble i see gas flow in the carb.
what are the typical symptoms when gas line goes bad?
could it be clogged carb?
bad gas? gas seems a little blue..using quicksilver oil
yelp !
yelp !
