mattman122
- Joined
- May 7, 2013
- Messages
- 4
- Reaction score
- 0
I have a bass tracker tx17 with a 60hp merc on it. the only issue I have with it is when i go from an idle to put in gear it will die.(forward or reverse) I have to resort to revving the motor with the throttle lever and then putting it into gear. I have cleaned the carbs and still having the same issue. once in gear and running I can slow down to an idle without clicking it out of gear and have no issues. once it clicks into neutral and I try to put it back into gear it dies. any ideas?
