Does anyone have experience with the connections of the throttle and shift cables on a tiller outboard? I removed the gears that the cables connect to to shift the motor to fix another problem and in doing so the throttle cables came loose from the gear they were connected to. While they were loose and I was trying to get them reconnected the slack in the cable caused them to also come loose from their connections in the tiller handle. I removed the side plate to access the cables in the tiller, but have not been able to figure out how they are supposed to be properly reconnected in both locations. Anyone with any knowledge of this is greatly appreciated. Motor is a 1993 Mariner 25 hp.
