Jiggyjigger
- Joined
- Jul 5, 2013
- Messages
- 2
- Reaction score
- 0
This motor has started what it seems like revving up while still in gear. I thought it was popping out of gear but the prop is still spinning. It revs up just past idle on the twist throttle . I pulled out the clutch dog and spun it around yet got the same result. Is there another clutch of some sort? Is it possible the driveshaft between the motor and gearcase could be the stripped? How much play/ wiggle should I have in the "pegs" of the clutch dog where it connects to the gears? I'm lost. Please help
