JoshKeller
i got this motor for really cheap. however, i havent worked on anything this advanced or new. it is a looper. cant provide the serial or model number because i lost the tag when i had it off painting the mid. however, i know for sure its a 1998 model.
Got the Carbs rebuilt and it idles great. great spark on all 3 cylinders that jumps 3/4". carbs were sync and lynced after rebuild. pulling plug wire from each cylinder each has the same effect. However the motor still won't open up. Verified it not being a fuel problem by spray gas and oil mix into the carbs and no change. Figured I had nothing to lose so I ran it on the water hose - still won't open up there either. Pumped primer bulb while running and made no difference. Here is in the water video and one on hose. Any ideas? possibly a slow mode because the oiling system isnt hooked up?
https://youtu.be/EwIiE4rHyN8
https://youtu.be/8c28Znn-6Wc
