desanmr
Good Morning Forum,
A month ago I was using my boat on a rough busy day on the lake. The waves from the other boats had me continually speeding up and slowing down. Finally the engine stopped and would not start again. After an hour of pulling my butt off, I finally got the boat restarted by switching from choke to non choke. The engine would rune. but not idle well. Went 100 yard and then got pulled over for not going slow enough under a bridge. The cops stated that they stopped me for going above a no wake, but seen for the past hour that I was working on my boat, needless to say, I was not happy with them and my boat never restarted. (Used trolling motor for the next hour to return to the dock)
When I got home I found the plugs fouled. I bought new plugs, extra plugs, and a plug wrench for the boat. I changed the plugs and took the boat out this week. When I got to the lake, the boat refused to start. This engine has always been a one or two pull starter.
Question 1 - This is a two cylinder engine, could I have put the plug wires on the wrong plugs?
Question 2 - Is there any other ignition issue that I could have over looked?
Question 3 - Can I please get a copy of the repair manual.
During my initial drive that day, I took the boat for at least a two hour ride before having issues. I have no idea what else to do.
I was a mechanic for GM 20 years ago, so I do know how to repair cars very well, but have never worked on a two stroke. With a manual I am sure I could skim by.
Thank you,
Michael
Thank you,
Michael
