brokenjack
- Joined
- Sep 10, 2013
- Messages
- 8
- Reaction score
- 0
Here are some pics of what you need to disconnect before removing the powerhead on a 1976 Evinrude 25602 manual start 25HP outboard. The manual suggests you remove a lot more. If you just want to remove the powerhead to get to the shift linkage for example, all you need to do is remove the following. It's doable for the average wrench turner. There is also one E-clip that needs to be removed(No Picture) on the inside of the carb silencer that connects the lean/rich knob. I'll try to post the bolt locations for the powerhead itself. I didn't take pictures before I removed them. I'll take photos after it goes back on. The reprint manual sucks identifying these bolts.
(one already disconnected)
Hope this helps somebody out there. I'm nearing the end of my "Off the Shelf" resto on my 1965 Starcraft Marlin. I'll put together a comprehensive post on what I did soon! Stay tuned!
