fishjunky
I bought a boat used that had been sitting for several years with this motor and took it out for the first time and had trouble with it.
The guy said he pulled apart the carb and cleaned it, but did not rebuild it. He put in new plugs and a new gas line and primer bulb. When I looked at it, he ran the motor on a hose collar and he kept it revved up pretty high but didn't think much about it. There was about a 1/2 or 3/4 gallon of gas in the tank that he said was just bought.
I bought non ethanol gas, marine stabil and quiksilver oil and topped up the gas tank. (Should have thrown out the old gas)
First time out I had a heck of time getting it started. When I finally did get it going it would choke itself down unless I kept it revved up.
The bulb got firm at first but later would not get firm. At one point I removed the hood and noticed a little fuel had leaked out of somewhere.
Eventually I got it running well enough to leave the dock and it was difficult to shift in gear due to needing to keep the rpms up ... I had to pick my moment to idle it down to shift. When I finally got it going forward and I opened up the throttle it would want to go and then start bogging down... then get going a little and then bog down again.
Also I noticed the fitting between the gas line and tank would leak a little when priming the bulb. Not gushing out but noticeable. Could this introduce air and keep it from picking up enough fuel? I have ordered some form-a-gasket to correct this.
Sorry this is rambling, hopefully it makes sense. Any ideas on what I should do?
I'm really hoping correcting the leaking fuel fitting will make it work better, but I can't imagine that's the only problem.
