airbornemike
- Joined
- May 30, 2009
- Messages
- 104
- Reaction score
- 0
I purchased an 2003 30hp Johnson and noticed you can turn the older 25's into 30 and 35's. Can this be done with a 2003?
[url=https://tinboats.net/forum/viewtopic.php?p=348987#p348987 said:huntinfool » 16 Apr 2014, 18:11[/url]"]How are they doing this? Boring out the cylinder and installing a bigger piston?
[url=https://www.tinboats.net/forum/viewtopic.php?p=349098#p349098 said:Plasticmotif » Yesterday, 13:58[/url]"][url=https://tinboats.net/forum/viewtopic.php?p=348987#p348987 said:huntinfool » 16 Apr 2014, 18:11[/url]"]How are they doing this? Boring out the cylinder and installing a bigger piston?
No. Alot of OMC motors from late 80s to late 90s have the same block. The carb and intake manifold are the only difference.
I turned my 1990 Evinrude 20 into a 30 HP by adding first a new intake manifold then a new carburetor.
I'm not sure if you can do it on that year - you'd have to reference part numbers and look at diagrams. If anything were different, it'd be a larger carb.
[url=https://www.tinboats.net/forum/viewtopic.php?p=349290#p349290 said:mphelle » Yesterday, 21:58[/url]"]Have you mounted the jackplate and jet motor to the towee? https://www.toweemarine.com/ There isn't a lot of easy hp to add to that powerhead but it should be plenty of motor for that craft if you keep it light. Resist the temptation to add a 24v TM or electric start. I would recommend one of those cheap digital tachs that wrap a wire around a plug lead. https://www.ebay.com/itm/Hour-meter-tachometer-jet-ski-boat-sea-doo-polaris-3d-outboard-kawasaki-js-650-/321377385261?pt=Personal_Watercraft_Parts&hash=item4ad395bb2d&vxp=mtr#ht_769wt_758 Post some photos!
[url=https://www.tinboats.net/forum/viewtopic.php?p=349283#p349283 said:Nohasslekindaguy » 18 Apr 2014, 21:36[/url]"][url=https://www.tinboats.net/forum/viewtopic.php?p=349098#p349098 said:Plasticmotif » Yesterday, 13:58[/url]"][url=https://tinboats.net/forum/viewtopic.php?p=348987#p348987 said:huntinfool » 16 Apr 2014, 18:11[/url]"]How are they doing this? Boring out the cylinder and installing a bigger piston?
True, but the 30 has a higher rpm rev limiter than a 20 or 25. Probably have to change the ignition module to one made for a 30 to get the extra rpm or you are not really getting 30 hp. I'd love to convert mine, but the carbs are very expensive and hard to find.
