I bought this motor about two moths ago and when I bought the motor it ran horrible so at that time I spent the money and had a marina check everything and then fix what was broken. As I expected the Carb needed and rebuild along with replacement of the reeds. That was all done professionally about 5 weeks ago. Since then nothing but ethanol free gas has been used and I run the motor dry of gas every time I take it out of the water. Today after starting and running it a few times it took a bit more to start but then when I hit the throttle it would bog down and die. But if I put it in hear hit the throttle slowly as I pulled the choke it got on plain and I could release the choke and it was all good until I let it idle and it just died. The Marina will be getting a call in the morning but of nothing happens I will tackle it myself. Any suggestions? All help is appreciated!
