pletzy
Hey folks, I need to consult the motor gurus as I'm stumped!! I brought my 1991 Mercury 15hp 2 stroke out of storage (in my basement) to fire it up to get ready for fishing on tuesday. My motor ran like a champ a few months ago, but since being in storage for a couple of months, it will not turn over. I think I have it chalked up to a fuel issue, but can't determine the exact problem...
-Brand new fuel and oil are in the tank. The carb, float bowl and fuel filter have been completely drained of all old fuel.
-Carb has been pulled and cleaned and all the jets should be clear of any sediment.
-I checked the needle and seat to see if it sticks, but it doesn't seem to be. The float bowl is full of fuel everytime I have taken it apart.
-The choke works, I can hear it spitting fuel when the button is depressed.
-the spark plugs both have a great spark. I tried putting a bit of fuel in the chamber and nothing happens.
-The reeds were replaced a few months ago.
-Primer ball is hard and no leaks in the fuel lines.
-When the ripcord is pulled, nothing happens... it doesn't turn over or sputter.
Any ideas? I saw a dead spider sitting on the throttle... any possibilities there is a blockage somewhere? Help! I want to go fishing! Thanks in advance!!
