Glue or what to fix a 25hp merc cowling
scoobeb
I have a 25hp merc i just picked up and the motor is as clean as can be except the rubber around the cowling is a bit worn and one end is nearly torn.What type of glue could i use to tack it back up or is there something else i can use to do so.I know it's just cosmetic but i also don't want it to get worse.Thanks for any help.
Would think the 3m adhesive for automotive weather stripping would work just fine, or some 5200/4200, depending on what you come across 1st.
