Excellent motors, as long as they were taken care of.
Twin carb. They idle a little better than every other 25, which were single carb.
Never had an oil injector die. Have seen plenty of swelled oil injection lines get swollen and leak, but never seen one die. They idle a little smoother than the pre-mix 25's, which were the same motor but slightly different carburetion.
Can't think of any major ongoing problems with them. Duck hunters have torn them up but that's to be expected when jumping logs, trees, etc. They are easy to work on for the most part.
They are quiet and for a 2 stroke, pretty smooth running. Not necessarily a powerhouse, though, at only 395cc. They still make 25 hp regardless. Stock prop is 11 1/4" pitch which should be close for "most" boats. Heavier rigs sometimes like a 10 1/2" pitch (which is oddly enough, a stock factory installed 4 stroke 25 prop).
They are like most outboards, meaning no air filter. If under the cowling you see dirt dobber nests or signs of them being under there previously, figure on an eventual rebuild.
Not much maintenance needs to be done...plugs, impeller, greasing and checking is about all they require. They are simple-hence why I said easy to work on. I do like to check the timing on them if I have them in the test tank as it's easy to do. Sometimes an amateur will have the carbs off for cleaning and forget to double check the carb sync and the timing pickup after the job-and while it's not going to blow up by not looking at that stuff, I do it just because I like them to be 100% when delivered back to the owner. Not 95%.
Normally a dealer servicing is under $125. At least ours is. Most of the time, under $100 including impeller.
