fireball1983
- Joined
- Jul 5, 2014
- Messages
- 4
- Reaction score
- 0
I have an out board old 3.0 hp that calls for 24:1 ratio oil mix, do I still need to go by that ratio or does the newer oil mix allow you to decrease the oil mix ratio. every time I run it, It smokes really bad.but I will stay with that oil mix ratio if that is what it should be.While I run it in a barrel the oil that builds up in the water is a lot.does any one else have one of these older motors that calls for the heaver oil ratio mix that has used a smaller oil mix
