Hi All,
I scored a great Craigslist find this weekend. I picked up a 1985 Evinrude 50hp from the next town over for $100. It was run about 4 years ago and placed in the garage when a new motor was added. It was advertised as a 70 hp (owner sold a couple of motors that day), but had the cover of a 60 hp on it. I was expecting to buy a 60 when I got there, but found out by looking at the serial number that it was actually a 50. Oh well, don't look a gift horse in the mouth right? I handed him the $100, put it in my truck and drove off as quickly as I could to make sure that he didnt' change his mind
I haven't done a whole lot with it yet other than remove it from my truck, but I'm comfortable with the fact that even if it's impossible to get it running, it's easily worth more than $100 in parts alone. I need to get it mounted on my stand so I can work on it a bit. First thing I'm going to do is drop the lower unit and inspect / replace the impeller. It didn't come with compatible controls, so won't be able to easily start it without hooking it up to my boat, but I'll give it thorough cleaning and check over before going that far.
So here's the issue. I'm currently running an '89 40 hp Evinrude with tilt & trim on it. I would really like to put tilt & trim on this motor, but unfortunately the T&T on the 40 won't fit on 50. I've seen a number of T&T units on Ebay that could work, but most of the ads don't give any model number, only the motor it came off of or a few compatible models. Does anyone know of the compatibility of this motor with others as related to the T&T?
As a second more general question, what would most of you do: 40 HP with power T&T or 50 HP with Manual tilt?
Also when I looked up the model number it shows up as a Belgium Derated motor. Does anyone know what was done to derate it? How easy to bump it back up to the normal rating?
Any lines on a compatible tilt/trim or controls would be appreciated. Not sure how much I'm going to spend until I get it running though.
Thanks!
Thanks!
