CountryRN
Hey all. I have weird problem with my outboard that I hope someone can shine some light on. I was cruising down the lake this afternoon and the outboard decides to spontaneously trim it self up. I was able to stop the upward motion as long as I held a finger on the down tilt switch on the throttle. I killed the power, reversed the Green/Blue tilt trim wires under the cowling and was able to get the motor back down. A few minutes later I happened again and again and again. I noticed that it occurs most when running at a higher speed (18 mph and above). Despite the wires being in the reversed position (up and down reversed) the motor still wants to trim up when underway, so I am presuming that the issue is not at the throttle handle or the switch on the side of the powerhead.
I sure there is a short in the wires somewhere but where. I am usually pretty good at tracking down issues like this but time is currently limited. Therefore I am checking to see if someone has suffered a similar situation.
The motor is a 1996 Mercury 60 HP ELPTO and is mounted on a center console Seaark.
Any ideas would be appreciated. Thanks.
