89 johnson throttle control
warefishin
Guys I have learned tons from this board and I always appreciate your help, I have another question for you.
My Throttle is kind of sticking on my motor, If I give it a lot of throttle it will not throttle back down.
My question is this, should the motor automatically push the throttle back or does the cable actually pull the throttle back to starting position.
If the cable is supposed to pull it back then my cable is broke because it doesn't.
If the motor pushes it back then I may be missing a spring or something, I am looking for a little direction.
What do you guys think.
I had hoped it was just the screw missing in this picture but it wasnt.
