santeerangerman
- Joined
- Jun 2, 2014
- Messages
- Reaction score
- 0
Got a 1997 War Eagle with a 92' Johnson 25 tiller.
Been sitting around for 6-7 years now, not getting a ton of use, and the past 3 years, none at all. Got heavy in the bass club/open Tx stuff for a while, but now i want to back off that.
The older Johnson is in good shape, but has some issues. GOT to convert it to electric start. Needs a new power pac, throttle cable, and of course, water pump replaced. I'm going to add a CMC PT-35 also. I'm GUESSING I'm going to be well north of $1200,00 by the time I get the Johnson the way I want it. The compression is above 100 psi and both cyl are with-in 10% of each other.
So I've also been looking at newer engines. For roughly $4000,00 give or take, I can get a brand new 25hp 4 stroke ele start, with the trim, or add the CMC to it also.
I know the old Johnson 2 stroke is gonna be at least 30lbs lighter, run faster, etc. BUT it's still a 22 year old engine.
A newer motor will be heavier, and somewhat slower. How much slower, I don't know. Most anyplace I'll go in this thing is within 10 miles of a ramp.
So, spend the money on refurbishing the Johnson (I'm leaning this way, to be honest) or dump the old 2 stroke for a new engine?
Just like to hear ya'lls thoughts.
Thanks.
Thanks.
