Hi All,
I've been working on an older Mercury 4 hp Gnat motor. It's running really well and has good compression. My issue is that the splines in the crankshaft have stripped out. Now I know that this is normally a death sentence for most motors, and this being a Gnat, it already had two strikes against it. Earlier today, I welded up the end of the driveshaft and recut the splines, hoping that there would be enough meat left on the crank to spin the prop. Unfortunately, it seems that the crank is completely stripped.
Now I'd hate to toss this motor because it runs so well, but I'm not going to toss the stupid money that would be needed to replace the crank. I was driving and I had a crazy thought this afternoon:
What if I weld a 6 point socket to the end of the crankshaft? Then I could drill and weld a nut onto the driveshaft, slide the lower in place and use that assembly to replace the splines.
Am I way out in left field with this one?? I know that I'd have to pay close attention to the alignment of the socket to the crank. I thought that maybe even using a deep well socket with two or three nuts aligned and welded together to increase the bearing surface.
I wouldn't be considering this if I was talking about a 150hp, or even a 50... but for my lowly little 4, I don't imagine that there would be enough torque to break that apart.
Now, I know that once the nut was welded to the driveshaft, I would have to grind it off to replace the waterpump, but I just replaced it this year, and it should have some significant life left to it.
If this doesn't work, I'm going to have to part it out, which will be a challenge of it's own as not many people still have these motors.
Any thoughts??? Suggestions??? Alternatives????
Thanks!
Thanks!
