traybore
So a buddy and I went fishing yesterday. Got the boat in the water, motor started right up. Went about 2 miles out to a potential fishing spot and killed the motor. Fished for awhile(no luck) and decided to move, turned the key and the engine cranked but would not start. I always make sure to check the water stream before heading out, and periodically while moving. It was always solid, so I don't think it overheated(it has done that before and not started when the impeller failed and I didn't notice) Checked gas, fuel pump, etc. All was good. So after a VERY long trip back with the trolling motor, the day ended. I got home and pulled the plugs, they were wet, so it was definitely getting gas(probably flooded after the repeated start attempts). New plugs, grounded them to the block and cranked it, no spark at all on either plug wire.
Im not sure what would have failed so abruptly to cause this? Coil? Seems like there would have been some signs of failing ignition components, but I don't know. Any ideas where to look? What to test first and how?
Thanks all!
Thanks all!
