Daretofish Active member Joined Jan 21, 2014 Messages 33 Reaction score 0 Location Suffolk Va. Nov 26, 2014 #1 Hello, I have two Johnson outboards that have the push style kill switch, has anyone converted these to the newer style lanyard safety switch?
Pappy Well-known member TinBoats Supporter Joined May 15, 2010 Messages 3,667 Reaction score 325 Location Central Florida LOCATION Lake County, Central Florida YOUTUBE https://www.youtube.com/results?search_query=pappyfromthekeys Nov 26, 2014 #2 Super easy to do if that is what you want. One wire (from the switch) goes to ground and the other (to the switch) comes from your ignition plate or, on the later engines, from the black/yellow lead.
Daretofish Active member Joined Jan 21, 2014 Messages 33 Reaction score 0 Location Suffolk Va. Nov 26, 2014 #3 Thanks Pappy, I am interested in what kill switch to use, will it replace the existing push button? how much$$, pictures?
Pappy Well-known member TinBoats Supporter Joined May 15, 2010 Messages 3,667 Reaction score 325 Location Central Florida LOCATION Lake County, Central Florida YOUTUBE https://www.youtube.com/results?search_query=pappyfromthekeys Nov 26, 2014 #4 Would you like me to come up there and do the install for you as well?? Am sure you can do your own homework and look up part numbers and prices. Marine Engine is an easy place to look up parts.
