Trolling motor mount
bassguytom
5
Post by bassguytom »
I have a transom mount trolling motor for my 12 foot Jon. My question is can I mount it on the side of the boat so I can reach it to steer from the front seat? Just wondering if this will work.
jethro
Post by jethro »
I've done that before. It works but was not ideal since the side of the boat is much more flexible than the transom. Use two long pieces of wood on either side of the boat side (you'll need to make up some space anyway) and it won't flex as much, but it still will. It also doesn't track the boat straight on long runs, but for fishing it's not bad. The flexing of the side of the boat is not going to hurt anything, but it can be a bit annoying.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
bAcKpAiN
Post by bAcKpAiN »
I have done it as well, you can also turn the head around to better steer from behind the motor. Like Jethro mentioned it is less than ideal and you will probably want to do something different in the future. I did see a guy at a local lake that turned the head on his transom motor around and used it from the back and just fished with the back facing where he wanted to go as if it were the front of the boat. If he wanted to make a "run" he just spun it 180 degrees and went the other way until he got where he wanted to fish.
JMichael
Post by JMichael »
I've done it as well and the boat not tracking straight was very annoying for me.
Post by richg99 »
Consider turning the head and using it as a front mount, if the shaft is long enough.
DO YOUR PART, STAY APART!
Pappy
Post by Pappy »
Post by richg99 »
Those are all Gheenoe mounts. I side-mounted a TM once. On a Gheenoe, too. Worked all right.
Pappy
Post by Pappy »
I know they are Gheenoe mounts....I own a Gheenoe.......Those mounts are presented as an idea only. They can be adapted to any boat that has a deck or bow cap. Can be made out of wood any size you like or whatever material you like.
Post by richg99 »
Pappy, I know you are a renowned Gheenoe owner and tinkerer...Just thought many others might not know for what boat they were made. I agree that they can be used on many other boats, too. richg99
bassguytom
5
Thanks guys. I am going to create a front mount instead with the performance issues.
turbotodd
Post by turbotodd »
I had one mounted on the side for a long time. 1432 flat bottom. 9.9 Johnny on the back. It works excellent on areas where you're not trolling a lot, like you're sneaking up on the fish. Turn the outboard fully in one direction and it offsets the tendency of the trolling motor to track the boat sideways. Besides there were many, many times when tracking sideways was a big help when sneaking in between Cypress trees.
