water into boat from jackplate only in reverse
bptjr
Stone Mountain Georgia
15/48 Alumacraft - Vance jackplate - Honda 9.9 .Water GUSHES into boat coming up thru center of jackplate only in reverse with a moderate throttle. Im trying to think of how correct this or block it without causing another problem. Any ideas would be helpful. Almost forgot to say motor is up 5.5 inches.
I have the same issue with my TH mini jacker. I picked up an old aluminum road sign and will be using some of it to make a block / dam for the mini jacker.
