1983 25HP Johnson.
It'll fire up, and run. Idle for about a minute and then act like its running out of gas, and then die.
If I take it above idle, it'll die even faster.
Fuel squeezy bulb will still be moderately stiff.
I took the fuel line off the fuel pump where it goes to the carb, and put on a line that dumped into a can. Started it up and it idled on the fuel on the carb for about 30 seconds. No fuel came out of the pump.
This would indicate a bad fuel pump, correct?
Just want to make sure before I tear into this thing.
