1994 Mercury Tracker 40hp Thermostat Location
tomflkeys
Does anyone know if a 1994 Mercury Tracker 40hp (4 cylinder 2 cycle) motor has a thermostat?
Also, if so where is it located?
I even removed the housing for the switch box and coils but could not locate the thermostat.
Any help will be appreciated.
FWIW I have a '97 Merc 4-cylinder 2-stroke and it uses an electrical thermal switch vs a coil spring-type thermostat. I also bought the Merc OEM service manual on-line for < $20 if I recall. You need the OB model number to pick the right one ...
Thank you for your reply.
Do you remember where the thermal switch was located?
Where did you purchase your manual?
