had issue with no spark. ran some test, trigger was bad. just got trigger today and dry tested it and got spark now..Is there any trick to adjusting the trigger without me having to buy a locator ring tool?
There should be a little ledge on the timing plate under the trigger pickup. You'll need to align the trigger with this ledge. If you've got a straight edge you can use it to help align.
