Mark_Fisher
As a 4-stroke newbie, I just bought a ~2003 honda BF20D manual start. Used it for two days. It started easily and ran like a Honda - solid, torquey, and quiet.
Then I took the motor off and left it on the foreshore while I worked on the hull. It was on its side, and I suspect that high tide got up to the carbs. (Not a submerged motor, but perhaps above the "down side" of the engine.)
The next day the motor would not start. Spark was good. The plugs appeared wet, and my standard 2-stroke fix -- pull the plugs, blow them off, open throttle and pull it over to clear fuel -- did no good. No visible water in the oil
Two weeks later and 500 miles away, I've drained the float bowl & refilled it, pulled the plugs and blown them dry with compressed air. I have gotten it to run for at most a minute, and never without the choke (Fuel enrichment valve) off. I am the proud owner of the $51 service manual (BIG!), but a little disappointed that there is little "Why we designed it this way" material.
I'm guessing that there's a passage or three in the carb that isn't open.
Does this make sense?
Any thoughts about rebuilding Honda carbs?
