Has anyone removed a lower unit from a 95? i can't for the life of me get the **** thing off? removed the bolt in the shift linkage, all the bolts.... any ideas?
Four in front, two on each side ... but did you get the 5th one in back? Remove and look under the gearcase adjustable 'trim tab' fin used to counter steering torque ...
i removed what i thought was the shift linkage.... :twisted: when i realized what i really needed to remove i had to remove the starter to gain access to the nut and the unit dropped! now to start the unit rebuild
