I just picked up this 1993 i mean mint 20hp 2stroke mercury and i just can't sell it as it was my plan from the start.I will post pics once i clean it up a bit and then you will understand why i can't sell it.The motor is so clean from top to bottom you can eat off of it,i just want to clean it up a bit from sitting in storage for over 17yrs and replace the few parts to the right factory original specs.So my plan is to clean it up a bit and i'm replacing some things i think it needs for my peace of mind.It runs perfect but it is a 1993 and i have no idea what had been done to it.The old man i bought it from says it's been used very little and it shows but things still wear out from sitting.
I guess he had a issue on the coils,don't know the whole story but i'm putting new coils,new complete wire set on it,complete full water pump kit including the housing and everything under it,new plugs,new lower unit oil and new lower unit plugs and gaskets,complete fuel filter assembly with the hoses and all and a new pull cord.I'm doing this all for peace of mind whether it needs it or not.My question is i don't like messing with the carb if i don't have to but i can do it with no issues,it doesn't leak a drop and works great.Should i just go ahead and do it to even know it works great.The things i'm replacing do need replacing imo because there is 2 different coils with the wrong size length wires even know it runs awesome i just want it correct with 2 brand new coils and wires.When putting the cowl back on it's darn near impossible because the latch gets caught on the wires so i am going to do it right.The wires were a bit long and worn so that is why i'm replacing them.The water pump i have no idea when it was done but it has awesome pressure but it's an easy job.I figure if i'm going to do all this i may as well do the carb.I'm just doing the gaskets if i do it.I will go over the whole thing though if i decide to do it.
So i ask,should i just do the carb gaskets as well or leave it alone?Nothing leaks and i would hate to mess with it if it works right but it's also probably the original parts to.
