Homemade surface drive
Tylermk5
CedarRiverScooter said:
Very cool!
Is that a belt (can't see it well)?
If so, is it notched so it doesn't slip?
Thanks,
Yes its belt drive. its a 130 mm notched belt.
wmk0002 said:
Cool! What was the cost to build? What size motor did you pair it with?
I built my buddy one and he furnished the materials for both. So not sure of an exact cost. But if you could find a metal shop that would sell you only the material you need. Probably 800-900 for aluminum,belt ,pulleys and ,prop. I put a 13 hp i had just to test it out. I'm about to put a 20 hp on it.
Did you make your outdrive unit (tail) or buy it somewhere? That is a neat unit. You have made the wheels start turning now. I have the stuff here to build one, I know there would be a bunch of trial and error involved but that is what makes it fun.
I made all of it. I would be glad to let you in on my errors. Maybe save you some time and money.
KMixson said:
Nice! Is there some kind of trim so you can trim down farther than it sits in the picture?
I believe you would adjust that with a travel limiting stop bolt under the pivot. That would limit the travel down. If I am incorrect I am sure he will chime in.
Yes nccatfisher that's right here are some better pictures.
Btw testing out a buddies 20 hp so please excuse the wiring.
I see. The pictures he posted explain it a lot better to me. Thanks.
