answer3
First of all I apologize if this is a naive/stupid question... I am a new boater with not much experience... I have a 9.9hp 4 stroke Mercury outboard bought new last winter that I used all season and the dealer winterized at the end of the season. I started it for the 1st time this year and it fired up after a few pulls, smoked and then I run fine it for a few minutes but whenever I pushed the choke back or reduced the rpm it shut off. After trying again a few times it consistently does not hold the idle position and dies. For the few seconds on idle I can keep it does not sound as smooth as it did last year.
I am guessing maybe the carburetor is dirty and does not suck up fuel as it should? The fuel was stabilized with an additive at the time of winterization so I suppose it should be good. The fuel demand valve next to the tank is only 1 year old so I assume it does not come from there either. Is there any easy test I could do to see where the issue comes from without having to take the whole carburetor out and open it? Maybe I can just play a bit with the oxygen/fuel ratio screw to see if it can make it run smoother at idle?
I would appreciate your thoughts on that.
Thanks!
Thanks!
