1998 Mercury 40 hp - no compression on 1 cyl, how bad of a scenario could this be? I don't have much information on the motor, but was wondering how big of a fix it might be (obviously depends on what the real problem is).
You almost answered your own question. LOL It could be something simple as a head gasket, albeit it would have to be severely blown and you most likely would hear it whistling if that when you spin it over quickly. With 0 compression you almost have to expect the worst and if not be pleasantly surprised if it isn't.JL8Jeff said:1998 Mercury 40 hp - no compression on 1 cyl, how bad of a scenario could this be? I don't have much information on the motor, but was wondering how big of a fix it might be (obviously depends on what the real problem is).
onthewater102 said:no compression? sounds like the compression gauge wasn't attached correctly. Unless it sounds like a punch of bolts rattling around in a coffee can there should be some compression.
