It is currently 21 Mar 2019, 15:46
 Page 1 of 1 [ 4 posts ]
PostPosted: 27 Jun 2016, 20:58
Well, the fuel pump works fine, the motor seems well suited for the 12ft 1956 Alumacraft RB, but...
first water trial ended with half-dozen high revs instances on the engine with no speed increase. Apparently the vulcanized rubber between the bronze center and the aluminum prop started slipping. It was like pulling in the clutch on a cycle, lotta noise, no speed. It didn't show up in the barrel at home, but the increase load and sustained higher RPMs must have caused it to start to slip.
I got a very used spare, but the poor old thing was run in sandy water (I'm told) and ended up with the blades a full half-inch more narrow than they should be. Not perfect, but temporarily functional.
But lord luv a duck, I have never priced props before!
I'm looking for a used, intact, propeller. Or, someway to repair the original prop.
All suggestions welcome.
TYVM
Kis
Enjoy every sandwich
1955 Alumacraft Model A
http://www.tinboats.net/forum/viewtopic ... 08&start=0
1959 Alumacraft Model F
http://www.tinboats.net/forum/viewtopic.php?f=3&t=25386
1980 Alumacraft Model F7, 1955-56? Johnson 10hp
viewtopic.php?f=4&t=35326
1956 Alumacraft Model RB
http://www.tinboats.net/forum/viewtopic.php?f=3&t=39249
PostPosted: 28 Jun 2016, 21:26
AOMCI is your friend!
Go to www.aomci.org and to the webvertise section. You should find what you need fairly quickly.
PostPosted: 28 Jun 2016, 22:28
Go to http://www.aomci.org and to the webvertise section. You should find what you need fairly quickly.
Thanks. I'll look there and some local sources.
How was your Motorcycle rally/ride? Did you get caught in that heavy weather down that way?
(Edit: Found a replacement prop. Will put it on and test it this afternoon. Should be fine, and the source was only 20miles away. :) )
Kis
PostPosted: 01 Jul 2016, 10:49
The ride was fantastic! Weather was stellar and the sights and roads were more than I had hoped for. I guess I should look up that thread and update it huh?
Users browsing this forum: blackshear, Google Adsense [Bot], kdgrills and 65 guests
TheRescueStep
